As I said in my last post - a full day of work with three people and a forklift... But we did it!!
Started a bit out of order, moving the axles (this is my friend and Air Force buddy Matt driving the lift):
Then we spent 3-1/2 hours getting 8 bolts off the flatbed - this was difficult not just because they were rusted in place, but because we couldn't get the wrench on the nuts (welded on tools boxes and other small stuff like the gas tanks and suspension in the way...) - that and we couldn't actually see the nuts:
Anyway, they came off eventually using some magic (Jedi stuff, they are still usable) - and we got to play with the forklift again:
Matt and Pedram (high school friend I mentioned I reconnected with earlier in this thread, not pictured in any pictures actually - lucky guy
), cut off the clearancing steel for the flatbed that had been welded to the frame:
Then we got to work stripping the front clip and separating the cab from anything attached to the engine:
And we pulled the cab and set it aside:
And as you can tell by the long shadows it was already after 4PM by this point (a bit after 5PM if memory serves). We then tore into the engine mounting and systems - retaining as much on the engine and tranny as possible for cucvnut (another Matt). After the sun really started going down, we had the engine out, shrink-wrapped, and dropped into the delivery truck (Pedram's):
And though we didn't take pictures as we were doing it (sunlight was fading fast), we did get the original pickup bed on the original frame, and the body safely stored on the flatbed (now on the ground behind the truck). This is the perfect configuration for me to work on the frame and engine bay. The axles are "roughly in place" (I do need to remove the original suspension to do the 4WD suspension work).
Continued...
