Cumminstx
- 0
- 0
- San Antonio Texas
Alright guys, these might be some silly questions but i am in a bit of a bind. I have an m923 that the transmission cooler/heat exchange line, made contact with the exhaust manifold and cracked.
This lead to the transmission draining out while going down the highway with out me noticing for a pretty long distance. Once we stopped we noticed that we only had reverse. so we had the truck towed back to San Antonio. I repaired the lines and refilled the truck with fluid and it still only has reverse. If the truck is in R its goes into reverse, if the truck is in N its goes it reverse, if the truck is in 1-5 its does not move, if you give it throttle, it only lets the truck come up to 1300 RPM. Once you turn the truck off, and starts rolling forward pretty rapidly for about 12 feet. So i pulled the transmission oil pan and it looks pretty bad in there.
So the questions are:
is the transmission shot, or is there something im just not doing right.
if the transmission is shot, what is he best way to fix it? is there some place that rebuilds these transmissions? or should i get a Pull Out?
if there is a place that rebuilds them or sells pull outs or even new ones , does anyone have any contact info?
or do any of yall have one for sale?
last an final question is i have found a few non running truck on GL for pretty good prices, should i just buy one and pull the transmission out of that?
Any help would be appreciated!
