Gasser vs Multi Fuel tanks
Crash_AF
Colorado Springs, CO
My new gasser has 6 year old fuel/rust/dirt sludge in the bottom of the tank (about 1/4 in thick or thicker under the filler). Should I try to have it cleaned or just get another tank? Are the gasser and multi tanks even the same?
Thanks,
Joe
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
I had mine cleaned at a heavy truck place. I think it was 35-40$. The tanks are different but you could probably make one work.
gringeltaube
Staff Member
2,641
Montevideo/Uruguay
Crash_AF said:
... Are the gasser and multi tanks even the same?
Thanks,
Joe
Basically yes, except for the size of the fuel pickup/pump mounting flange and the two additional 1/4" NPT ports according to following diagram.
It should not be to difficult to use a MF tank in a gasser removing the pump and adapting the gasser pickup tube.
G.
Barrman
1,986
Giddings, Texas
RE: Re: Gasser vs Multi Fuel tanks
I am using a multi tank on my Gasser. The mechanical pump pulls the gas out of the tank past the not used intank pump just fine.
maddawg308
792
Appomattox, VA
Anyone have a pic of the tanks cross-section? In other words, from the side, to show the location of baffles, etc.
