unclemikey
- 97
- 0
- south west
Have been playing with the front bumper and all the wasted space out there. Mounted a semi-pioneer rack in front of the radiator over the winch, it carries a Hi-lift Jack, shovel and axe. Gives good protection to the grill and radiator. Very good place for the I.R. lights to be mounted and is very stout. Behind the bumper I built a lower rack that mounts a 20mm ammo can on both sides for tools, chain and junk ( I had removed the under cab tool storage to mount a step fuel tank ) the ammo cans take up the slack. Behind the ammo cans I can mount two more Jerry cans or two more removable ammo cans. Behind the Jerry/ammo cans I can mount a NAPA wheel chocks between the the turn signal and hood on the 45 of the fender that lays up against the Jerry/ammo can very securely. With the ammo cans mounted, it gives a great platform to stand on to work under the hood. I removed the bumper mount step and built a small two step ladder that mounts onto the driver side ammo can, this can be dismounted and put in place faster than the bumper mount unit could be deployed. It is very stable and can be mounted to either side of the bumper. Could not get a very good picture angle to show the above, but you will get the idea. See what you think !
or
![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
