- 1,137
- 113
- Athens, Ga.
So I was getting ready for a paint job before Aberdeen and I had just finished doing 2 pinion seals, transfer case input and output seals and a transmission output seals. I put it all back together and went for a test drive on a Friday night as I was taking a 50 mile trip the next day. About 5 miles from home, I thought I smelled coolant, so I pulled over at a gas station and sure enough, there was a steady stream of coolant flowing down onto the top of the front axle. I always keep a 5 gallon jerry can with water in it, so I topped it off and rode home.
Next morning, I pressurized the cooling system and threw a mirror behind the exhaust manifold and there was a stream coming down from between the deck and the block.
So began the great cylinder head party.
See captions for more info.
