15.50 and 14.50 xl tires on stock deuce rims
SpruceDeuce
Pittsburgh PA
Hi all,
I recently found a deuce on ebay that had 15.50 xl tires mounted on stock deuce wheels and i wanted to get some opinions on this as i am looking into putting 14.50 xl on stock deuce wheels
also i messaged the builder of the truck and this is what he said about putting 14.50 or 15.50 tires on the stock rims
"I use stock rims on the truck and USA 6x6 super single rims on the trailer. The super single rims are much nicer to work with and eliminate rubbing at full turn. The only issue is cost. I have been paying $250 per rim. The stock rims fit fine and if you turn out your bump stop screws you will eliminate wheel rub. Hope this helps."
"The 14.5x20 can be mounted on a standard deuce rim. You can reuse the flap, but a new tube is needed. I use firestone 13.00/14.00 tubes. The hubs in the rear do need to be flipped. The only issues you will find are in the front. If you do not adjust your turn limiting bolts, you will experience some wheel rub. Hope this info helps. Let me know if you need anything else."
here are the pictures of the 15.50s
maddawg308
793
Appomattox, VA
Hmmm. Very cool! Do you think it may be possible to dual the rear wheels for a wider footprint, or are the meats too wide on the rims for duals?
gimpyrobb
dumpsterlandingfromorbit!
27,786
770
Cincy Ohio
From what I understand, you really should use a wider rim for that tire. That being said, I doubt duals would work.
SpruceDeuce
Pittsburgh PA
maddawg,
i certaintly do not know for sure but my guress is that they are too wide and being radials they squish out at the bottom on the sidewalls and would certaintly touch in a dual configuration
i really like the way it looks singled and the fact that you do not have to look for the special, rare, and expensive rims makes it a lot easier i really want to put the 14.50 on the stock wheel i just want to get some other opinions on this
comdiver
Buffalo NY
The stock wheels are 7.5" wide and stamped on the wheel it says 1200 is the max tire. The tire guys I have talked with say 1100's should be the largest. Off road, do what you can and want.
rizzo
Port Huron, MI
m-35tom
226
eldersburg maryland
RE: Re: RE: 15.50 and 14.50 xl tires on stock deuce rims
not a good idea. there is a reason michelin says to use 11" wheels
SpruceDeuce
Pittsburgh PA
thanks everyone for the info i guess i will look to the 1100s for now and one day get the big super singles
thanks again
gringeltaube
Staff Member
2,641
Montevideo/Uruguay
SpruceDeuce said:
...... i really want to put the 14.50 on the stock wheel i just want to get some other opinions on this
Do NOT mount 14.5R20 or other size MPT tires on std. deuce wheels (1.5" flanges), widened or not! The bead section of those tires is different and requires special MPT rims (1" flange height).
Some tires like the Continental 365/80R20 MPT81 are an absolute NO because of their incorporated protective rock-skirt which would interfere with the deuce wheel "horn".
See attached drawings.
On the other hand, MPT wheels eventually can be used for std. radials like 15.5/80R20, 395/85R20, 13.00R20, etc. although they only cover half of the bead area compared to the recommended 20x10" rims with 2" flange height.
G.
GoHot229
One of the benefits of these size tires is top speed due to their diamiter ie. one revolution @ distance traveled in feet, verses a 900x20. Of course a 50"+ tire will travel further per revolution than a 900. Given that you have a better top speed, it takes away from lower speeds and the gear ratios of your trans and transfer case ratio. Starting may require a low second to take off, especially if loaded, perhaps that is not the case, I dont have the big tires. But it seems 'grades' and acceleration would suffer quite alot, especially the uphill grades where 4th may be the norm or 3rd until you crest the top. For low speed things off road, they may be way nice, and look kool, but practicality may not be served.
Jakob
Louisville, KY
I'm confused about which tires SHOULD be run on widened Deuce wheels. I know we SHOULDN'T run the 14.5, 15.5 or the like. What tires are about 46" and will fit properly on widened wheels?
gringeltaube
Staff Member
2,641
Montevideo/Uruguay
