Funny looking headlight arrangement...
jblack6527
Weaverville NC
This may be the wrong place to put this, and if so, I apologize. I was surfing around on GL, and came across this deuce that has the headlights in a different place. Is there a reason for this, or?
bigmike
356
Dixon CA.
Mine doesn't have a winch and never did...and the headlights are above the blackout light.
littlebob
26
Baton Rouge LA
Don't quote me but I've seen the lower headlights mostly on earlier non winch trucks. I've seen the high lights on both W/W and W/OW trucks that are newer.
I'm sure David Doyle or someone else will chime in with a definitive answer.
littlebob
ida34
34
Dexter, MI
The older ones could be flipped either way. I am pretty sure the newer ones can not be flipped and are permanently in a position with the headlight above the BO Drive.
saddamsnightmare
80
Abilene, Texas
February 24th, 2008.
:driver:
GENTLEMEN OF THE BROTHERHOOD OF THE DEUCE (or a Dueced Brotherhood?)
Note also that M. Walker's Duece in the picture above has the opening for the Sparton horn above the right headlight, and I presume that his horn is likely electric. My 1971 Kaiser Jeep has the headlights high and the blaclout ender the left one, with the grill set accordingly, and she originally did not have and does not yet have, a winch.
Sincerely,
Kyle F. McGrogan
1963 Mercedes Benz S404.114 Unimog (Swiss)
1971 KAiser Jeep M35A2 Wo/W "Saddam's Nightmare" Vietnam and Desert Storm Veteran Deuce Truck.
rofl
ida34
34
Dexter, MI
I had thought the decision on the light placement also was affected by the horn being air or electric. It seems like electric horn models have the horn mounted above the light with the light in the lower position while the airhorn models are flipped like the winch models. As said before, I think the newer models do not flip and can't be flipped with the headlight down.
emr
25
landing , new jersey
the horns had nothing to do with it, the original reo design had low head lights when they came with a winch as stated above they were raised, later models "still early" to us had all raised headlights...Randy
ida34
34
Dexter, MI
All the low headlight trucks I have seen had the electric horn. Cause or not that is what I have seen in my experience.
shadow
Cedar Rapids, Iowa
My 53' reo is lower as well. I suppose I could take the horn and blackout out and put headlights there and have "Low beams" and "High beams" :D Get it? haha. But that would make it a real 4 eyed monstrosity . :lol:
