OD Iron AC
taylordc15
Sale Creek, TN
Ok I have read countless post on AC in the M1009 but have not seen any comments on the kit offered by OD Iron. Has anyone done it? If so did you do anything to insulate the firewall? I have the arctic heater kit can it be made to fit?
1,820
I don't think it will fit with the banks. It mounts the a/c compressor just outside and below the right alt. As far as the winterziation kit, I'd need some pics looking straight down from above the right alt to get a better idea. Another note, it requires the relocate of the BO switches so a vent can go in. If you don't have a stereo installed, that area makes a great place to put the relocated switches.
Michael
24
Fulton, MS
I would love to see some pictures of the install. Do you know if that is all of the instructions that you get? He has 4 pages posted on the above link. No mention of the condenser or its mounting.
1,820
I can tell you this, it's no walk in the park, done by noon install. I'll try to scare up some pics but the install still isn't complete.
devilman96
17
Boca Raton, FL
I will get you guys some pics in the morning . . kenny is right though, its not a 5 min install but I should have it gassed by Friday this week.
devilman96
17
Boca Raton, FL
Underhood work... I should note that the fan was changed out for a 6 blade flex fan to help up the CFM at idle... This is not part of the kit but something I thought would help cooling over all...
Starlight
West Palm Beach, Fla
AC
Hey guys, I see it comes with a square louver but can you tell me if it has the other louvers above the glove box ? Trying to find out what the kit doesn't have. Thanks,T
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
I can see better cooling at an idle, but how well does that flex fan work at highway speeds in the heat of summer? My old big-block Nova wasn't happy at all with the flex fan at highway speeds. It tended to act like a solid wall and restrict the airflow at highway speeds. Changed to an electric fan and lost 10-15 degrees on the highway. Given that we wind these trucks up pretty good at highway speeds, I would have the same fear? Let us know how it behaves.
Nice product, BTW!
1,137
As always, your stuff looks good, D-man.
devilman96
17
Boca Raton, FL
wow thats gonna be tight... I would need a measurement between the alt and whatever gadget is next to it (blower housing?)... The battery box bottom rear corner would have to be modified (notched out).
Why keep that kit on in CC Tx?
devilman96
17
Boca Raton, FL
I believe it will fit in there as the compressor sits quite a bit lower than the alternator does... Note I say "believe"... I still think you will need to notch out a corner of the battery box... but I’m not for certain on that ether as I’m told the arctic kit battery trays are narrower, but I don’t think narrow enough.
