Deuce Locking Door Handles
rmgill
14
Decatur, Ga
I think I found a good source for the Deuce's locking Door handles. I went through homedepot and Lowes and couldn't find the right handles. Seems the Genie line has the locks in the face plate and not the handle and the Stanley hardware is special order only now (meaning you'll never get it from Home Depot). But, tonight I was perusing the PECO camping catalong and lo, there was the style of handle that we need with key locks. I'm going to swing by the camper store tomorrow and see if I can get a set and make up a set.
Djfreema
Santa Clarita, Ca
Ive got one those on my truck. It works good keeping looky loos and kids out but if somebody really wants to get in and steal the truck, it wont be a challenge. I only put it one the drivers side since the passenger side can use the inside door handle lock. A little spot weld on the screws would be good to keep someone from just taking the handle off from the outside and being able to get in.
rmgill
14
Decatur, Ga
Locking handle success!
Here's the first comparison of the two locks. The curved handle is the stock door handle. Nice, but no lock. The straight one is the $9 handle from PECO Campers. Seems like there's several makes of these out there. The replacement handle's square shaft is a bit longer than necessary. And the stock shaft has a square section cut at 45° angle to the shaft.
rmgill
14
Decatur, Ga
The holes on the handle I bought are slightly further apart, a difference of about 1/4". I milled out the holes a bit larger (8 shaped) with my drill press and added a pair of cutouts for the screw heads. This puts the screw heads slightly under the handle's edges.
rmgill
14
Decatur, Ga
Sand blast or sand it by hand, prime and paint and then mount it up. The hole spacing was tricky, it took a bit of fiddly fitting, but I got it all together. I need to touch up the paint as the screw heads marred the paint/primer trying to fit the screws. Insert them into their holes, then insert the square shaft/handle and turn to it's aligned point.
