jpekarek
- 10
- 0
- Vancouver, WA.
Well I finally went ahead and tore into the rear axle to replace the seals. It was not very hard. Just heavy. I followed the proceure from "dm22630" and there were no problems. I tried to document everything with photos so others can see what's in there before they start.
1. Park on a FLAT surface & set your parking brake.
2. Chock wheels.
3. Jack up the leaking side of the axle.
4. Remove both tires.
5. Remove axle shaft.
6. Remove axle nut, lock nut, outer wheel seal, & outer wheel bearing.
7. Remove hub/drum assembly (80+ lbs....DONT slide across your axle threads!).
8. Remove inner wheel seal & inner wheel bearing.
9. Clean everything (brake shoes, brake drum ** clean & lightly sand to scar surface **, remove all old wheel bearing grease & gear oil from inside hub).
10. Pack bearings.
11. Install inner wheel bearing & inner wheel seal.
12. Install hub/drum.
13. Install outer wheel bearing, outer wheel seal, lock nut, & axle nut.
14. Insert axle shaft & remember to use high-temp RTV sealant to seal completely.
15. Reinstall tires.
16. Remove Jack.
17. Fill gear oil in that axle.
18. DONE!
2. Chock wheels.
10. Pack bearings.
16. Remove Jack.
18. DONE!
