New Tire Setup on Deuce
M1075
Oklahoma City
I have been running Michelin 11R20 XL tires on my deuce in dual configuration and have been very pleased with their performance. Today, I got a wild idea to swap out the 11R20s in the front for 14.5R20s on M35A3 wheels. Tire diameter is the same and I thought the wider tire in the front might look good. What do you guys think? Yeah or nay?
M1075
Oklahoma City
Re: RE: New Tire Setup on Deuce
tbrenner said:
Looks good but shouldn't the left tire be flipped around.[/quote
Yeah, probably. Even though I think these are non-directional, it would look better flipped. The tires were already on the rims and I just bolted them on to see what it would look like. The truck drives nice and smooth up to at least 60.
breelanr
Elizabeth, CO
They look better facing the same direction, but if you look at a M35A3 - all of the tires are mounted the same on the wheel. The tires on the right have tread in one direction and the tires on the left in the other.
rmgill
14
Decatur, Ga
RE: Re: RE: New Tire Setup on Deuce
I'd agree it looks nice. However, now you have to carry two different types of spares.
How much did the XLs cost?
M1075
Oklahoma City
The truck handles very well. I was expecting some rumble or vibrations, but didn't notice anything. I think the best tire combos for a deuce are Michelin 11R20 XL (duals) or Michelin 14.5R20 XL (singles). I just merged the two. The 1100s came on the truck and I bought the 14.5s through GL for a couple hundred bucks. I would like to get more of each tire. Since they are the same diameter, I could carry one spare. I think I have an NDCC on there now. If I keep the 14.5s, I've got two more spares!
steelsoldiers
4,089
Charleston, WV
Looks very nice. The wider fronts balance out the 11R20 duals in the rear. I say keep it!
1,137
I like the front, but love the rears. Looks good.
citizensoldier
17
Northern Michigan. Smelt City
Looks very nice to me. I do have a couple questions. I was told you can not run the 11.00/20 Michelin XL radials in the dual configeration because under a load they can rub? Do you ever load this truck and drive it very far? I guess the sidewalls on a radial realy flex and will cause heat and a blow out. Just wonder if you ever noticed any problems because I would like to do this with my M109.. I like the look but think it would look better and perform better with the 14.00's and A3 rims all the way around.. Just MHO.. Nice truck... like it allot...
M1075
Oklahoma City
This Army installed the 11R20 duals on it. Some people say it can't work, but it has so far. I have only carried a couple tons with it, though. If tire failures exist, I'll be sure to report back. I think 14.5s all the way around would be good. I just don't have that many A3 rims.
Bjorn, I'm not sure what the weight distribution. Maybe I can get it across the scales soon. With the winch, it is probably good to have the heavier tires up front.
jeli
Stillwater, MN
I'd run a single 11x20 for a spare. Being the same diameter there's nothing wrong short term mixing fronts like that. It may pull a tad but beats investing in two spares.
1,819
Looks great. Love the XLs. Wished I could switch but doubt that I can afford 34 of them. I've been seriously considering switching everything here to 1100x20 NDTs. Hmm?
