Is there an air operated power steering unit available?
EZFEED
Lafayette, LA
I am thinking about doing some mods to my Jesterka and I want see if I can hook into the air system to power a steering unit and get away from the 12VDC one? Is such a unit available surplus or aftermarket?
If not maybe grafting a hydraulic system from a heavy truck in might work but I wouldn't have any idea on how to actuate it on a manual steering box which I have an extra of.
Any ideas guys :D ?
Capt.Marion
15
Atlanta, GA
I'm not sure exactly how the Air-O-Matic system works, but for the manual steering box, the Deuces all have manual steering boxes unless they have a hydraulic or air-o-matic system installed. So it theoretically could be made to fit. The end I'd be worried about is how the steering arms and everything would hook up on the front axle... someone with more experience would have to chime in.
comdiver
Buffalo NY
The Air-O-Matic has two major components. There is an air valve that installs in place of the draglink and an air cylinder. When you turn your steering wheel, the drag link either pushes or pulls depending on the direction you want to travel. If it is pushing, air is allowed to travel from the truck's air system to one side of the air cylinder, if it is pulling, air goes to the other side. The cylinder applies force to the tie rod, giving you power assist steering.
I have an air-o-matic unit I would like to sell. PM me.
