S.E.E. cab tilt
bchauvette
12
Easley SC USA, 29640
View attachment 60-Body.pdf
Attached is the civi cab tilt instructions. The TM says nothing about the Cab Tilt Bracket. Also the TM is not clear on unsnapping the hand brake cable can cover. You need to extrapolate the instructions that apply to us.
Note: be sure to mark the steering shaft alignment before unhooking it.
I use a ratchet strap tied to the roll bar and the lifting ring below the back window and an other strap as a safety so I don't overshoot when tilting.
