alabamafrog
- 1
- 0
- Huntsville Al
Well I joined the ranks of MV owners this week with my purchase of 2 trucks and 3 trailers. However on the way home with the new 5 ton flat bed I had several bad problems. The most notable are it is stuck in low range, will not go over 20 mph, when the shifter is shoved very hard it will go down like it is in high range but it just sits there and makes a light grinding noised when put in gear. So I had to drive it to my friends shop 6 miles away at 20mph.
Then when I turned left into his shop the front rear axle came loose and twisted up under the truck into the fuel tank and leaf springs. Also the batteries were dead and disconnected and the brakes were jacked open and an air line fitting was broken off. With 1200 miles I thought it would be like new and ready to drive around only needing fuel, boy was I wrong.
Is this normal???
I thought these things were near indestructible and I can't even make it 6 miles with it driving easy without it falling apart.
How can this be fixed?
The other truck I got has 59 miles and is a 5 ton dump truck, it does not run and who knows what I will find wrong with it.
Why do the axles fall off when you turn left too sharp?
What the heck would I have done if I was surrounded by zombies when that happened!
Is this normal???
