Air Dryer for an M35A2
shootiniron
13
Escalante,Utah
Been looking and really no joy yet.Where to find an air dryer for the A2?What about the cost?Any ideas as always will be greatly appreciated.Thanks!
Rustygears
Ramona, CA
If you are looking for one to cover the entire truck air system, the stock one used on the A3 is the commercial 'Haldex' model 'Pure Air'. These are very common on commercial trucks and are simple and rugged as well as designed for both extreme heat & cold.
They are available through many discount truck supply sites and flea bay. The automated self-cleaning feature is really nice.
Alredneck
Banned
1,494
15
TN
I asked about a Bendix unit but they want 3-400 bucks and I though that was ridiculous. I do reccomend one but would comb the junk yard and find a good used one. Also the make sure your govenor is free from gunk and working with in its PSI ratings. The one on my deuce and M54s look just like the bendix govenor on my International. I think the new one for my International when we replaced the air compressor in it was 75, the compressor was almost 600. Fun Fun when You have truck trying to make money off them! And now it sits with a blown motor!
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
What does the heat do? I know I got a refrigerated compressed air dryer for my shop air and that cold makes the condensation drop out. I don't see how heat can help.
  • Like
Reactions: HDN
m-35tom
226
eldersburg maryland
the drain area is usually heated on the pressure drop type of dryer but i have never had a problem with no heat on mine.. it just keeps the moisture from freezing on really cold days. you should bve able to find a used unit for $50.
tom
  • Like
Reactions: HDN
Blood_of_Tyrants
11
Lebanon, TN
From what I know about air dryers, they come in two flavors.
There is the mechanical type that uses refrigeration system to cause the moisture in the compressed air to condense on some refrigerated tubing (the compressed air is circulated passed the tubing). The moisture is gathered at the bottom and on the better units is automatically dumped.
Then there is the desiccant type which means that the air passes through a chemical that readily absorbs the moisture. However, when the chemical is "full" of moisture, the way to get it out is to heat it for a period of time, usually with a built in heater. Since this means that the dryer will be out of service for a period of time, usually several hours as the heat drives out the moisture, this isn't an option for many people. But it is a good option for the hobbyist as it is much cheaper than a refrigeration type dryer.
  • Like
Reactions: HDN
m-35tom
226
eldersburg maryland
but we are talking about vehicle air dryers and neither of these are used. the only common type is the pressure cycle type where beads readily absorb moisture from pressurized air and release almost all of it when the pressure suddenly drops.
tom
Rustygears
Ramona, CA
The replacement filter kit has both spin on filter and new dessicant cartridge as well as a few other items. It takes about 10 minutes to replace these items and no special tools. Once done, you essentially have a completely new dryer, except for the housing. If you get a used one cheap, put the replacement kit (available multiple places selling OTR discount truck supplies) and get a factory fresh dryer system. I did this on my A3 and I no longer have any moisture in my wet tank when I open the purge valve.
  • Like
Reactions: HDN
Rustygears
Ramona, CA
The Army used the Haldex "PureAir' as the stock 24V model (heater included) in the 'A3. That is a very common commercial unit used on many big rigs. It's really bulletproof. I've seen them on flea bay for under $100 NOS. Probably available elsewhere surplus as well.
  • Like
Reactions: HDN
gimpyrobb
27,791
791
Cincy Ohio
Bringing this thread back.
I ended up getting one of the A3 type air dryers. The guy selling it was worried that it is listed in the CTIS(should use lots of air) section of the A3 TM. In all of the searching I have done, NONE of the air dryers for trucks list a cfm. Is this a concern I need to worry about or not. Everything I have read leads me to "NOT", but I wanted to be sure.
  • Like
Reactions: HDN
rosco
32
Delta Junction, Alaska
The only trouble fre air dryer is the alcohol snifer. They are adequate for all weather conditions, even the extremes that we encounter here in the North. The one that often comes with the M35A2 is adequater and trouble free.
rosco
32
The snifer is all that you need! Drain your tanks daily. Go to a heavy truck shop and get the "Pull Cord" type drain cock, so you don't have to crawl under there. The only modification to the stock Deuce snifer, is to wrap some duct tape around the jar and the metal top, so that jar doesn't rattle loose, and fall off.
cranetruck
94
Meadows of Dan, Virginia
Agree with Rosco...why add components that will make the operation of the truck more dependent on the batteries... besides, it's not a bad idea to use an alcohol evaporator along with you "dryer" too.
My xm757 has 3 stages of air tanks and there has never been any moisture in the 3rd tank in my experience. It came from factory with an alcohol evaporator/vaporizer.
