- 3,228
- 3,279
- NORTH (Canada)
M35A2C running like a champ. Upgraded primary and secondary fuel filters as of this spring, in-tank pump working, fuel level over 1/4 full.
Situation: driving on country road, no issues, engine warm. Shifting back before doing a right turn. Stepping on clutch, engine dies. Coast to a stop at side of the road after the turn. Will not restart and sounds out of fuel. What I mean by that is that there were no "warning signs' such as power loss, a strange sound, etc. The engine died the same way as shutting off the fuel. When cranking, it did not attempt to fire, as if there was no fuel.
Shutoff pull is pushed all the way in and locked with accessory switch arm.
Visual inspection of IP and area reveals nothing. Shutoff pluner moves freely and is all the way out. In-tank pump humming.
For lack of clue, play with shutoff a bit, move it back and forth. After that, engine restarts and runs with no further issues.
I do not know what the cause could have been. does that sound familiar to anyone? Anything I should check, specifically?
