peashooter
- 205
- 63
- Hanover, minnesota
M35A2/M109A3
I've done some searching for the best speeds to get the best mileages but since so many folks are using different tire setups its a little tough to compare.
I'm assuming that there might be a "Sweet Spot" in RPM's that would give the best miles per gallon so I wanted to see what other folks run at.
so far my 109 is getting about 8mpg with cruising @ 2K rpm (45mph). Tire pressure is 65psi front, 55 rear.
I dont expect much better mileage but I'd be thrilled if I could manage to taste double digit mpg once in a while.
