2012 Ga Rally parts wanted/for sale/swap thread
mikev
73
Culleoka, TN
Anyone need military paint...
... (especially gloss white for your armor interiors)? :D
I'm bringing a tri-wall full of:
* 41 cases (1 qt + hardener) #34031 Aircraft Green (dark OD)
* 7 cases (1 qt + hardener) #383 Green
* 15 cases (same as above) #1263 White
* 14 cases (3 pints + hardener) #17925 White
* 11 cases (same as above) #4123 Clear (epoxy coating)
* 25 cases (6 qts + hardener = 2 gals/case) #4123 or #17925 White
* 5 gals of #16473 Aircraft Gray (enamel, alkyd, ext gloss)
* 5 gals of #383 Brown (by Hentzen)
* 3 gals of #34127 Olive Drab and Green (enamel, alkyd, lusterless)
* 4 gals of #37038 color ? (didn't open yet)
* 5 gals of #17038 Black (most without labels - might be lacquer or enamel)
* 3 gals of #17875 White (enamel, alkyd, gloss)
* 1 gal of #37030 Black
* 3 gals of #14062 Green (enamel, alkyd, gloss)
And bringing many cans of enamel and lacquer spray paint - mostly red, yellow and some OD and bringing some other gals of CARC green, brown and black not listed above.
This paint is not new (made in the nineties, but still fluid) and in dusty boxes, but you can open them for inspection and the prices will be reasonable.
First photo show start of filling the tri-wall - it is now filled to the top...
CARNAC
The Envelope Please.
717
College Station, TX
My intent is to come on Friday and part of Saturday. I might make Thursday but doubt it.
I'll be bringing a bunch of folding cots (NOS)--$30 each
water cans--$15
fuel cans--$30
2 x ice chests (I think the type that holds 200# of ice)--$50 each
2 x 5 ton tarps (used/good)--$150 each
Various wood and plastic boxes
Dragon missile rubber duck
SA7 Grail rubber duck
Will probably have a bunch of other crap....I mean high quality merchandise.
Come see me when I get there. First coming with cash gets it. I have A LOT to do in one week so come get it quickly.
GerWJ
six mile, sc
need brake bleeding kit manual
need the manual for the army brake bleeding kit, one we used on in 60's and later
thanks
will be on site on Fri morning
slave cable adapters
24 volt 12000# winch $500.00
24 volt drills yupp they plug right into your slave port
air dryer kits
plus alot of 5 an 10 kw parts will bring them if ask for only so much room pm or call about them
also lots of new gauges too if you need it pm me so i can load it
ratchet , crank for 820 expando brand new
Towbar light kit brand new never used
Plus lots of manuals too
shelter halves
DOG TAGS IF I CAN FIND A POWER SORCE
wreckerman893
Possum Connoisseur
15,647
2,141
I will have about 20 sheets of laminated DOT approved glass. I don't want to bring any of it home so deals will be made.
I have a decent set of slave cables (has a bare spot) that the first 100 bucks (or interesting trade)will get.
I also have a bunch of stainless steel stuff that came out of the photo shelter I bought last year. All types of containers, beakers, buckets, pans and stuff that was used to develop film.
If anyone is interested let me know and I'll load it up.
No one has spoken for the two AC units. I may bring them anyway for trading material.
vinny-socom1
Ocala, Florida
NEED: Fuel transfer hoses from the 24V slave cable driven 35 gpm fuel transfer pumps. I'll be bringing two to four of the pumps after I check them out for function and will sell them for what I paid GL.
Soon, I will revise my parts list and post some photos of some parts I'm bringing.
I will be bringing USGI issue Panasonic CR123A 3 volt batteries (for flashlights/weapons lights) - 10 per box for $10 a box.
I am still trying to get additional Hawker batteries; however, the 22 spoken for will be brought to the rally (don't forget your "wallets and cores")... :)
put me down for a box!
Vinny
vinny-socom1
Ocala, Florida
I found some things that need new homes
1 canvas dump bed cover nos
2 NOS canvass 20' long bed cargo covers $300 ea
20 Un- assembled NOS duce-900 cargo bow w/fiberglass stakes $12. ea
3 44,000 lb tow bars $400
I've got a deuce/5ton tow bar-expandable- would you be willing to trade...I don't need anything that heavy now.
Vinny
Makincold
Mansfield, GA
I have a good set of (4) stock size of tires for M1008/M1028 Goodyear AT - LT235 85R16, pic is of the worst one of the lot, more pics if you want them
$60
LMTV Troop seats, cast/extruded aluminum. NOS , 2 sections which I think are for one side. I was going to use them on my M818 / Deuce bed conversion but went a different direction
$200
M818 5-th wheel and ramps, I believe this thing has never seen a trailer on it. At the moment its coming to the rally as a bed weight for the trail ride. If no one takes it home it goes to the scrapper
$200 or an "interesting trade" on this item
poppop
39
Brooklet, Ga
Anybody out there need the main hydralic pump for a John deere articulated loader. I cant remember the model but can post the part number if anyone is interested. They were in the first Desert Storm and must not have been needed. they were still in the JD boxes but the boxes were in bad shape.
5,161
Where's the rest of the M818?
pctrans
19
Bradenton, FL
parts
Partial list of what I have available, and will try to fit into the cargo bed.
Troop Seats:
4 sections 5 ton Longbed, all fiberglas, real nice cond - $150/set
M817 Troop seat set - $150
Deuce Wood/fibreglas set/headboard - $150
2 deuce troop "SEAT" sections only, fiberglas - $50/ea
Deuce steering gearbox - $40
M105 metal bows - $10/ea
Large new air tanks - 9.5" x 37" - $20/ea
Humvee run-flats, 16.5" - $8/ea
5 ton Gasser fenders, 1 left/1 right, - $75/ea
1 RH 800 series fender - $75
Fender support brackets - $10
818 spare tire rack, w/air lines - $50
817 toolbox/tire rack - $75
Snap-On plastic toolbox w/metal drawers - $20
20" beadlocks (metal/rubber) - $15
800 series fuel tanks - $75
800 series steering gearbox - $75
Deuce toolbox/step - $50
8 and 12 bolt Humvee rims, 16.5" - $50
818 rear fenders - $10
M105 side rail set, tan, little bruising - $75
M105 side rail set, tan, Nice - $100
M105 side rail set, green - $100
M105 tan cover, decent - $75
M101 tan cover, decent - $100
M101 Bow set - $50
900 series spare tire davit, NOS - $20
10 - Metal bow corners/uprights - $5/ea
4- New Split rim rings - $5/ea
Deuce heater box with switch - $50
800 series sprague clutch, NOS in box - $200
Deuce artic grill cover - $25
800 series fuel tank selector switch - $10
Cargo cover hdwe kits - $10
NOS Deuce air filter, in box - $20
900 series mirror brackets - $25
Dual Genset selector switch box - $25
900 series Hydraulic kit (less PTO) - $100
48" NOS muffler guards, tan or alum - $10/ea
800 series Cummins air filter housing - $10
New Deuce pressure plates - $60
Red Fire Truck light bar, works fine - $100
5 ton longbed Cargo Cover Kit, Artic White - $450
Deuce Cargo cover, tan, some stainage - $100
Deuce Bumpers, nice and straight - $100
Slave cable outlets (cab mount side) - $20
Let me know if you need additional pics of other items. Larger items I won't bring unless someone commits. Thanx, Pete.
pandctrans@gmail.com
