Exhaust j-pipe installation problem
Happyland1410
Ada, Oklahoma
I just attempted to install a new j-pipe and ran into a problem. The new pipe is one of the newer ones that has welded sections instead of one continuous pipe. Well, after having issues getting the pipe in place I compared it to the original and they are a little different. The end that goes toward the turbo is angled slightly different and is an inch or more longer. This makes the flex pipe from the turbo too long to fit in between. I collapsed the flex pipe as much as possible but it is still too long. Has anyone else run into this or did I just get one that was built wrong?
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Pic's would help, you are bolting it all together before tightening anything up right?
doghead
4 Star General /Moderator
1,182
Where did you get that pipe?
I've not seen any that look like it.
It looks like a poorly/cheaply made replica.
Happyland1410
Ada, Oklahoma
doghead
1,182
Interesting.
Sorry, I have no good answer other than to cut and fit as needed.
barefootin
South East PA
I purchased one last year and had the same issue. I had to cut it and shrink it. At first I managed to get it in with the use of four letter words and way too much time wasted, but I couldn't get the flange on the fender nor the hanger underneath aligned because of how long it was.
Happyland1410
Ada, Oklahoma
Did you cut out a section in the straight portion of the pipe or at the bend near the flange?
barefootin
South East PA
I took mine out at the bottom of the "J". But that's where mine was different from my original. I put it on the truck, cut it till it fit, tacked it together and then removed it and finished welding it.
dutchguy
Lawton, Michigan
I put a new one in my Deuce last winter, it too was a little too long. Lots of cussing, finally got it in, wrecked my arm and pinched the crap out of my finger, and the pipe is right up against the outer edge of the cutout in the fender. I don't suppose it's easy making a pipe when you don't have the original design dimensions. Still seems like it should be closer that what you are seeing though.
Warthog
234
OKC, OK
The pipe is a NewStar item.
must be for the new Korean version of the trucks.
Dan you said you just wanted a new pipe. Not one that fits....
Happyland1410
Ada, Oklahoma
Yes, I should know to be more specific in my requests :grin:
When my daughter was about 3 we were getting ready to go somewhere and we told her to go find her shoes. She leaves and comes back in a minute without her shoes. When questioned about why she did not do as told, we were informed that we told her to find her shoes (which she did) not to actually get them. :doh:
I'm going to take the pipe to a muffler shop tomorrow and see what they can do with it.
FYI: the pipe itself is much heavier than the original and aluminized so if I can get it to fit it should last a long time.
DieselBob
15
Arnold Maryland
The best thing IMO to the longevity of a exhaust pipe is keeping moisture out. Capping it when not in use and getting it up to operating temp to burn off any condensate that might make a acid when left to mix with exhaust soot in the pipe. 2cents
Happyland1410
Ada, Oklahoma
Well, I finally have the new j-pipe installed. I cut out a 2" section and welded the pipe back together and then it fit. But the fun didn't end there! I got everything repainted, bolted back up and then went to put the stack on. Would you believe that the flanged end was too small for the stack to slide in? So, I had to take everything back apart and cut the flanged end off of the original pipe and weld it on to the new pipe. After spending most of the day fixing this poorly made j-pipe at least it is done and my huge exhaust leak is fixed.
Warning to everyone: Don't buy a deuce j-pipe from NewStar unless you need to practice your welding.
Truck Replacement Military Parts and Components on S & S Truck & Tractor Parts Co.
barefootin
South East PA
Crap... I forgot I had to modify that on mine also since it's been so long. I just trimmed mine down until it just fit inside the lip. However, I did purchase mine from another source...
Warthog
234
OKC, OK
Great job Happyland. Sorry about that. I did ask if you wanted a good used one.:razz:
See you tomorrow at the parade.
