- 10,350
- 75
- 48
- Meadows of Dan, Virginia
The flasher unit on our trucks are prone to failure simply because the new ones are built with Radio Shack parts and appear to have no overload protection. The encapsulant hides all.
I dissected several units for an article a few years ago and since this subject comes up so often I thought I'd summarize my findings with a solution as well.
Image #1 below is a typical schematic. Simply an oscillator with a transistor driver rated at 15 amps.
The inrush current for 8 or 10 lamps (not uncommon with a trailer hooked up) can reach 75 amps and it's no wonder that the flashers fail.
My solution is to add an electromechanical relay to the circuit so that the flasher unit never sees more than the relay coil. Image #2.
In addition to protecting the flasher unit, the relay puts full battery voltage on the lamps, they are a bit brighter as a result. There is always a small voltage drop across a transistor.
The relays (one for the headlights also) have performed flawlessly for over a year now and the 4-way flashers were used extensively during my cross country trip.
Image #3 is the preliminary set-up to be used on the XM757 8x8. It may seem like an overkill, but I like it that way.
Merry Christmas!
PS. If you can find a flasher unit from the sixties, it was designed with a heavy duty SCR and could withstand an overload until a circuit breaker tripped....
Merry Christmas!
