82ABNMP
- 53
- 28
- Winston Salem NC
The M1008 has all new GP system/plugs/card/switch,starter relay upgrade ect... and the batteries are 6mos old group 31 Exide made in 2012.
Previously the volt meter has always been dead on the hash mark and Gen lights work correctly.
The truck has been sitting for a few months with weekly checks and start ups with no problems...until now.
The other day it’s 45 outside and the truck starts fine,but while driving the volt meter goes low into the yellow.
Park the truck overnight INSIDE and the next day...complete blackout no juice at all. So I switch out the batteries with known fresh ones and the truck fires right off with the volt meter in the greenon the hash mark. Parked the truck overnight with the second set of batteries OUTSIDE and try to start in the morning temp is 14...batteries have some juice but not enough to spin the motor over to start they are mostly dead.
One thing I have did notice (and have noticed before on other trucks with a short/drain) when I went to hook up the second set of batteries (fully charged) there were some sparks when attaching the cables...yes they are hooked up correctly. Is this normal? Or is it because there is a draw on the batteries? Which means I have a short/draw somewhere?
No wires are hot to the touch.
Why suddenly after months one day would it start to kill the batteries? How much of a draw would it take to mostly kill a set of batteries overnight? Did the cold kill them?
Thanks, David
Thanks, David
