Tires
Bob H
161
Huron National Forest, Michigan USA
36 x 12.50 x 16.5 on stock M880 wheels.
Truck has an extra leaf in the front.
Going down the paved road the outside 1 1/2 inch of the tread does not touch. which keeps the noise down.
They handle/ride better than I expected.
I won't keep these on this truck long as I can't risk the fenders :cry:
maddawg308
781
Appomattox, VA
I've heard that HMMWV tires on an M880 will eat the fenders when you go offroad. Is there a minimum lift that should be performed in order to safely put 36" HMMWV tires on the -880 series? 3"? 4"?
Bob H
161
N1265 said:
whats up with your bumper markings ?
???? Whadaya mean?
Don't know the real answer on the amount of lift req'd
Those tires rub on level ground, full turn.
but I think 3 inch would do it. trimming of the lower rear portion, of the front fende rwells may still be req'g but the fenders should clear
N1265
Fremont, Ohio
BOB Wrote : Whadaya mean?
The numbers on your front bumper look to me to be : 76401 - 7246 I was just wondering what they stood for I dont recall ever seening a bumber marked like that.
Hoot_223
are u still running the stock 4.10 ratio? with that size tire, i just got my 37x12.50R16.5 tires mounted, but i havent drove it with them yet, because i have had some manual transmission problems, i broke a shift fork
they are the goodyear MT military OZ
Recovry4x4
LLM/Member 785
1,820
GA Mountains
Thread revivied! Bob, I purchased an M880. Tires are crispy. I'm trying to figure a way to drag the truck home behind the deuce. Do you think I could put the 37" HMMWV radials on stock wheels and get it to turn enough to follow me home? The deuce is not a sharp turning vehicle anyways.
Bob H
161
Hmmmm.....
In my experience with a tow bar on things bigger & heavier than a jeep, it is rare that the towed vehicle wheels turn to full lock when being dragged around a corner.
The tires would likely rub on the rear of the inner fenderwells when turning,
the radial hmmwv tires have less aggressive tread blocks than the bias ply which may cause less damage if they did rub. on a right turn the LF would probably hit the pitman arm before the RF would hit the fenderwell.
In the 1st pic in this thread the tires are turned about as far as can be .
IIRC the pic you posted, the front does not seam to sag much, that is a plus.
If you could limit the amount the wheels could be turned somehow, i.e. rope or cable or blocks or something............ I'm sure the deuce wouldn't mind dragging the front of an 880 a little sideways on the tighter turns.
Also the 880 doesn't have a idler arm to help return the wheels to center, bungee cords from steering wheel to seat frame or????????
Just thinkin out loud here.........
Recovry4x4
LLM/Member 785
1,820
GA Mountains
Think I'm going to try it. Like you said, if worst comes to worst, I can lock the wheels down straight.
44CCKW
Port Republic NJ
The humvee tires will fit on a stock M880.But you cannot drive the truck. They will rub HARD on the steering linkage.You will need a 4 inch lift minimum to run them without rubbing. Also you will need to switch to a power steering unit.The manual steering linkage comes out the side of the box and will rub when turning to the right.I have a 4" lift and power steering on mine and have had no problems with it unless I get the truck really twisted up off road.Then they will rub.
Lawrence of Arabia
Howell MI
HMMWV Tires
I had them on my M887 in Saudi and just trimmed the bottom corners of the fenders and never had a problem. I recently put them on my ambulance with a 4" lift and it feels good going down the road but the front clip shakes pretty good at 55MPH.
