rtbcoop
- 0
- 6
- Tyndall AFB, FL
Thanks for the heads up on the inverter, however the revues of this product are not 100% +ve....... 5:2 fore/against.
Any concern about heat build-up inside the can? Did you have to vent the can or use a fan to keep the converter cool?I also bought the inverter, I have two spring seats in myM813A1 with two ammo cans mounted between the seats, I mounted the inverter in one of the ammo cans , and installed a 12 volt marine plug through the side of the can, now i can charge my phone , plug in my GPS , My 12 volt spotlight, CB , ETC.....
It works great so far!
Seems to me you'd want to have some cross ventilation in that can to keep the heat from building up, and shortening the life of the converter. A 12 or 24 VDC Muffin Fan would work well.You could always use a small 12v muffin fan on the side of an ammo can. Using a can is what I was thinking of doing as well with mine.
Yes but the output is still 24V onlyTo clarify you CAN do Parallel and Series at the same time but you need at least 4 batteries. This is how a 4 battery setup works in our trucks (correct me if im wrong please), 2 of each in parallel to make 12volts at double the capacity then you connect those two pairs in series to get 24 volts.
