acme66
- 9
- 0
- Plains, Montana
Tires, bed and air.
I started off trying to diagnose my random slow blowoff whistle at the air dryer. I did manage to find and fix a leak at a tank regulator but I doubt that was the problem.
After that it was off to think about how to mount the spare I have been reading up on how to mount a 20x14.00 behind the cab of a M923. Looking at ways to squeeze it in and the alternative of moving the bed. I am thinking of moving the bed back 3 inches and remounting the frame attachment points. It would require drilling 10 holes in the frame and that has always been taboo for me. The center point is bolted and the ends are riveted.
There is more at play than just mounting the spare. I am really thinking of mounting a lift gate as a simple solution to how to load my people into the back. That might also require moving the bed and I don't want to move it twice so for the moment the spare can ride in the back. Of course a spare in the back is as good as useless because while I can get it out, there is no way I can get the flat one back up. Speaking of the spare, its a Michelin and it is flat. I put the air to it and went around it with soap.
The rim joint wasn't the issue, it was plain old bead leaks. The front side stopped with air pressure and soap seeping in, the back didn't. First my helper and I marked all the spots it was leaking. This wasn't necessary but he found it fun.
I then drove a tire spoon down and in all the way around about 3 inches apart as demonstrated by my helper. Twice.
It never came off the bead, I guess that was a good thing but I would have liked to clean it properly. I blew it out real good with air and more soap. The same thing I would have done to a tractor or skidder tire with a bead leak. The fates smiled on our endeavor and she aired up without any bubbles. Took it to 55psi and I will check it in a few days to be sure. As long as I was on a tire kick (and to put off more thinking on the bed) I inspected the rest of them. They are all matching tread Goodyears. The front two are clearly newer than the rears and have had a softer life. I noticed some cupping on the outer edge of both fronts but can't say if it was or was not there when I picked the truck up. I drove it 1000 miles to get it home on mostly dry pavement so I am sure that could have cupped them...now I need to find out why.
I also have a damaged rim but I doubt there is anything really wrong with it.
The rear's are chunking very badly. As long as they wear evenly...who cares?
I need to look up how to read the tire codes then find out how old they all are and some of the marks on the spare make me think it sat flat on a truck for a while but for the most part I am satisfied. I think I will look into liquid balancer because when all the heavy spots line up it is like a trotting horse.
-Ken
-Ken
