CCATLETT1984
- 6
- 0
- Saint Clair Shores, MI
They are NOT the humvee plugs, hmmwv's run a straight 24volt system for everything. The CUCV only runs 24v for the starter, the glow plugs are run through a dropping resistor that is feed from the 24v buss bar. The dropping resistor lowers the voltage to ~14volts as soon as a load is placed on it. The reason that this is done is so you can jump the vehicle with two dead batteries using the NATO slave recepticle on the front of the truck. Otherwise you would have no 12volt source with both batteries dead.
