Oops. this one might be stuck for a while
Suprman
670
Stratford/Connecticut
Get some boards under the front tires of the sunk one if you can. Get the pull truck on better ground and extend the winch cable with heavy chain to make up the difference if its too far out. If the ctis works put it in sand mode you will get better traction
Recovry4x4
LLM/Member 785
1,806
GA Mountains
Ferro had his M818 of death stuck like that at the GA Rally a few years back. Bumper was on the ground and the cabbage was all built up around it. We were (I supervised) able to free it with one deuce and no winch. Lots of witnesses were looking on in disbelief.
1,125
That's because:
A. you guys are experts
B. miracles happen at the Ga Rally.
Kalashnikov
NH
That's not even that bad! I had the bed of my deuce on the ground on the driver's side and water coming in the cab PLUS the front bumper was IN the mud. Got it out with the winch and a snatch block.
Recovry4x4
LLM/Member 785
1,806
GA Mountains
C. - Recovery4x4 only stood by in the shade drinking beer and yelling instructions
This is factually inaccurate. Everyone who knows me, knows I travel with a cooler everywhere. I never stand when there is a cooler to sit on. I was seated while directing the extraction.
porkysplace
1,487
mid- michigan
Like most equipment a winch is only as good as the operator , If you don't know proper winching technics , serious injury can occur .
phil2968
17
Lakeland, Florida
He was drinking a diet Sundrop, Dewdrop? Something only he could enjoy! I think that's why he brings those, so no one else will ask for one!
M813A1
OKC, Oklahoma
what ever you do I would pull it out backwards that would make it easier to get unstuck !! If you drove it into the mud ,pulling it out backwards will be easier because you will not have to pull the heavier drive axles into the ruts . That way you will only have the drag from the front axle making it far easier to pull the heavier rears out first then the front axle. Good Luck
jw4x4
Dayton, Ohio
We consume mass quantities of Diet Sundrop, Diet Mtn Dew, and my favorite Diet Citrus Drop from Kroger.
jw4x4
Dayton, Ohio
We were told by numerous people that we would not be able to extract said M818 without a winch. We prevailed, and made astounded believers out of them.
jw4x4
Dayton, Ohio
No yelling was involved. The most difficult part of the extraction was getting everyone else to quit yelling useless suggestions. Once we were able to direct the 16 year old deuce driver to only listen to certain individuals, it went very smoothly. Too bad no video of this is known to exist. I doubt Neil Hendrix will ever forget that ride.
nk14zp
17
Columbia Falls Maine
It will have to be stuck for a long long looooooooooooooooooooooooooooooooooooooooooonnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnggggggggggggggggggggggggggggg time to beat Frodo's record.
