dangier
- 7
- 18
- Page County, VA
You guys have been great for help in the past. I have a new one for you. My 002a (3rd one), has been giving me fits and then some. Fixed a4 and vr boards and tested-work great in working unit. Still have no power when running on this one, but that is for later. IP was bad and have a working one thanks to Gimpy. Now that I have the unit started, I get all of the engine oil puking out the fill cap vent. I had done a compression test a while ago and got a reading of 380 and 385 IIRC. This was with my shop made injector adapter and a harbor freight gauge set. Pulled breather assembly and it was not blocked. There is just too much pressure for the breather to handle. I had left the bottom baffle plate in the block and started unit. Oil and the plate went 10 feet in the air..... Pulled head and everything looks ok to me. Pictures below.
View attachment 442561![002a03.jpg 002a03.jpg](https://www.steelsoldiers.com/data/attachments/303/303672-57d7ff1f883552198cf3297d1dbb68b0.jpg)
There is no scuffing or groves in the cylinder wall, so I would not suspect broken rings. Could the rings just be stuck?
Anyone have any other ideas?
Thanks,
David
![002a04.jpg 002a04.jpg](https://www.steelsoldiers.com/data/attachments/303/303673-87b91e613edc9cb66849c5e511b08485.jpg)
Thanks,
David
