MarkM
- 1,150
- 2,099
- WOBURN. MA.
It that a ceramic tile job or a surround that looks like tile? I also like the color.
Mark
Mark
90" x 41"What are the dimensions of that bathroom?
That makes sense. I didn't think of the piped being damaged. I was thinking the extra weight would be good over the rear axles. If you had done the design like that, you would have to have mounted steel or mesh on over all the pipes in that area. Might have been a lot more work. Are you planning on putting super singles on the back of the trailer to even it out with your M932 series truck?Thank you muthkw25. The space between the door and the wall/door of the bathroom is just over 4'. I did think about putting the bathroom across the front ahead of the side door opening. But after looking underneath, the 5th wheel is in the way of easily routing the pipes. Also this section is directly over the wheels, so anything that might be picked up from the tires could possible damage the pipes unless they were enclosed. I also viewed Rayzers build (the one that inspired this build) and looked at where he put his bathroom. I am sure, he has probably done it for similar reasons.
One the kitchen, I had multiple ideas, but it seem like it would be easier for fresh water and drainage having them both on the same side. I will be building out the cooking area next with an induction cook-top and refrigerator below in the same cabinet. A small fold down table will go in the front section of the trailer. Everything is put on hold for a few weeks while I use the trailer to move to Arizona. Part of the reason for keeping the rest of the trailer open. This allows you to still use the trailer for cargo when the occasion arises.
Started on the metal braces for the storage boxes and water storage tanks. The boxes have been sitting in my garage, and with the move, I could use the extra capacity. Should have some more pictures by next weekend with the boxes installed.
Rayzer, the framework is welded. And the clearance id 18" which should be fine as long as do not do any high incline/declines. I looked at some long horse trailers, and they are even lower. I needed to be 30" down from the bottom of the floor of the trailer so I could fit in my military boxes. I am hoping to have this completed this weekend in between all the Veterans Day parades. Next week I will move to Arizona, and need to have this portion of the build completed.Agazza, is the framework where attached to the trailer frame underneath welded or bolted? Theres alot of room under there now! How much ground clearance is there?
A commute would be nice, as soon as I get to work it would be time to go home. See you at the Parade tomorrow.Do you really HAVE to move to Arizona? Can't you just commute?
You're going to be missed around here, my friend!
Cheers
