Welder Sam
- 6
- 0
- Glendale, Arizona
Jeff, send that to me via fb please. I'm interested in that but cant make it out here.
Thanks
Thanks
Sam - do you need more pics or larger versions of those pics? I have a few more pics as I too am building a similar setup and have most of the stock/fitments etc.Jeff, send that to me via fb please. I'm interested in that but cant make it out here.
Thanks
Well if I was doing civilian trucks that might be true but the reason for using the wiffletree is I move military trucks by the shackles which are always the same unlike chains you are using I am looking at adding the swivel but don't think it is really needed.You will definitely want all three dimensions of movement between the wrecker and disabled vehicle. Most of the time your attaching chains will not be hooked at the same lengths...without the towbar being able to twist it puts a lot of force on one side. I built a holmes 750 "like" arrangement this past year and have had good luck with commercial road tractor reverse tows, unloaded tandem dumps, etc. Will attempt to post pics of assy this afternoon.
Regards, Bob
Mine came with 1/2 a box full of pulleys. Thought about trying to make some kind of rack for them but I have yet to get one out even.I have thought about a chain rack beside the spare for commonly used chains. Our truck came with 11 and and 7 pulleys and the tool boxes get full fast. Has anyone did anything like this?
I would love to do something along these lines - but we don't have ground access lockers on the 816/936...... Thought about trying to make some kind of rack for them but I have yet to get one out even.
Dang it Zebedee I all ready owe the machine shop a weeks worth of wages and now I am determined to cut off my front outrigger pads and open up my storage. Oh well as long as I am cutting I might as well do some other stuff too. It is Christmas after all! Guess I need to print out this thead and give it to Santa Claus.I would love to do something along these lines - but we don't have ground access lockers on the 816/936...
But may put lift gate spring/dampers on the lids to lift the weight of hooks/pig tails on the underside of the 3A 3B lids for the chain ends, so they are organised, also for some of the towbar feet maybe...
The big pulleys could be hung between the boom lift cyls on the turntable frame...
Yeah - I think this would be a great mod:........ and now I am determined to cut off my front outrigger pads and open up my storage.
I find my holmes gear very usefull. and to swing through 360 degrees. simply cut off the (floor) stops at travel limit.(viewed at the rear lower monting of the crane gear) easy with an angle grinder.Ron - I was trying to 'search' for modifying the crane from 270 deg to 360 deg rotation... didn't find anything!!!!!Tips?
DaveP, post #36 - do you have pics of the front side of the spreader - I need details of the swivel.
...but came across this old thread, which I can now add to.
Been fab'ing my version so have found a load of pics. Still looking for a scrap 850 Holmes unit to save time though.
Have found new US made 5/8 weld on grab hooks for the ends of the spreader bar tube.
Tube on the 850 is 5" ID x 40" long. Don't have details of pivot** (A frame connection) but swivel is with a simple sleeve that has two grease nipples seen in pic.
Suspension by whiffle tree - as pic of DaveP's 819 is a good option (cable is a bad idea) but I need to go with a pair of 5/8 chains, "Hammerloks" and a lift 'pear' ring route for authentisity of my project, similarly....
Ears I had to make on the rear body cross member are 3" by 1 1/2" with a 1 1/2" dia pins on a 4" 1/4 wall box.
Pic one is collection of civi units (750's mixed in).
middle pic is from an 816 on e-gay a month or two ago.
Soni's M123 (?) is also shown from his pics of the FEMTT build. (edit - added wrong pic3 - oops)
(NB Holmes 750 is a smaller unit.)
Okay I like that but here is what I am going to do. Remove the outriggers completely I never use them. Turn the toolbox lids 180°so they open to the front and the crane will never completely block them from opening. And I am going to do a door on both sides of the truck. And the sides are getting cut so they will fold down 90°. This mod starts in the morningOk - couldn't resist, or wait for anyone visually challenged to ask...
