quickfarms
- 25
- 38
- Orange Junction, CA
At 43,200 lbs and 51.2' it is possible but you will need a light tractor and trailer. You will probably end up with a 53' flatbed. Properly specked they can haul up to about 46,000 and still be under 80,000, it might be a little tricky to get the axle weights correct.The 923 is listed as 21,600lbs empty and is 307.4 inches long(25.6')
