Someone didn't start at the beginning, lolNeed what?
2 20'x2" recovery straps rated for 7000# http://www.homedepot.com/p/Keeper-2...ry-Strap-89924/202065652?keyword=051643899247That setup worked really well!
How much strap and what size did you get?
Congratulations on your successful recovery!
Nope...That last picture would make a great avatar!
That was the first thing I tackled. I figured since I was already soaked I might as well get underneath it. That's why I parked over the ditch to make it easier. I know I will have to get back under it just to rinse it off but at least I got the chunks off everything.Between now and tomorrow there is another step you can take for cleanup. If I have to leave mine before the bottom is clean, I put one of the cheap lawn sprinklers under the truck. It keeps the stuff loose and knocks quite a bit off while you sleep (if you don't mind running the water).
I was washing off the end of the driveway and it started coming down. Cars passed by, I could tell by the looks what they were thinking. Look at that idiot, pressure washing his driveway in the rain.Glad you got it out. I did a rain dance to send some water your way to help clean. It'll probably get there after you're finished, since my timing isn't what it used to be.
Or chains...Time to get rid of the old NDTs. Might have made it with a good set of tires.
Is that the zipper part on the front axles?I do not know if anyone mentioned it, but check closely for any tears in the front axle seal boots. If they leak, you now have destructive water and abrasive crud in the front axle drive knuckles. They will have to come completely apart and be cleaned and re-packed with grease. If you do not do this you will eventually be buying expensive parts.
Regards Martin Sacks
