lindsey97
- 15
- 18
- wynnewood, oklahoma
hello everyone, I would like to start a thread specifically about how the mt654cr trans acts while upshifting/downshifting.
my truck is a 1990 am general m923a1. I have owned it about a month, and have driven it approx. 600 miles. seems to be a very solid truck mechanically and cosmetically. all fluids are clean and filters are fresh. I have adjusted the shift cable 2 turns towards the front of the truck and it responded well by holding gears longer before upshifting and downshifting somewhat more firm.
what I am concerned with is the 2-3 shift and the 3-4 shift.
i'm very pleased with the 1-2 shift and the 4-5 shift while upshifting, they are quick firm and quiet.
downshifting automatically is also quick and firm, and the truck will compression brake almost like a standard. when the truck is put into gear at an idle, it immediately goes into gear and will begin to move without use of the accelerator. what I am saying is I don't suspect that I have a worn out or weak transmission. temperature of the trans fluid doesn't change my shift characteristics either. it runs 180-190f on the trans temp gauge.
my main concern and questions are how the trans shifts 2-3 and the 3-4 upshift. it makes "errrr aagh" sound and then the tachometer settles in and starts slowly climbing again. doesn't act like the trans is slipping, the truck is accelerating the entire time this strange sound is occurring.
what I suspect I am hearing is the torque converter lockup clutch. when in hilly terrain and lugging along, then trying to accelerate it will make the sound; then I intervene and manually make a downshift to 4th or 3rd, then step on the gas bringing the rpm to 1900-2000. this seems to work quite well to limiting the trans by selecting the highest gear available manually.
there is a place near my home at exit 55 I-35 that is slightly downhill at that intersection. if I take off from a dead stop and accelerate moderately thru all 5 gears letting the trans pick the shift points, it will shift very quickly and quietly, like driving a car.
what I am asking is this normal? does the truck have a torque converter lockup clutch? is it adjustable? is there a spring kit available for the valve body that changes shift characteristics? can you install a switch that manually controls torque converter lockup from inside the cab?
so far all of my experience with this truck has been unloaded hauling no weight or trailers.
please let me know how your trucks up shift and act. some real world advice and experience would be helpful here.
