M151A1 New to the fleet here in SoCal
blisters13
75
Beaumont in SoCal
Hey All:
Just got this M151 today and was wondering if anyone would like to say what's on their mind about it. I have restored a WWII Dodge WC-43 and repainted and maintain a 1968 M35A2. I will start restoring this jeep in a few months after I take care of some loose ends and sell the WC-43. I can do the body work myself. It looks like an un-cut body, although it has been hacked up a little. I also have the correct 2-piece windshield, seat frames, and a few other of the obvious missing body pieces. The guy I bought it from seems to have lost the rear axle shafts (half-shafts?), so I need a set of those. The ID plate shows original ownership by the US Navy; the paint seems to be 24087, although I think I see some bits of haze gray by the front bumper. Am wondering if USMC M151's were owned by the Navy or had direct ownership? What's the deal with the bright green paint on the engine and radiator? EDIT: I now have the drive shafts.
blisters13
75
Beaumont in SoCal
Some paint pics:
IMG_1247_edit.jpg IMG_1249_edit_web.jpg These are on the inside of the -A1 windshield
No hood numbers, original seems to be USMC forest green (I sprayed on some 24087 at top):
IMG_1260_web.jpg Guess this hood was a replacement
blisters13
75
Beaumont in SoCal
FLAT-TOWING TO STORAGE
Medium tow bar
Wheels turned wrong by themselves,
had to have a friend steer it to the
temporary place.
Whiterabbit
14
Bristol Va.
They all will turn to full lock while towing. Big heavy rubber bungee cord wrapped around lower spoke on the steering wheel to the seat helps stop that. That was standard practice when we'd flat tow 'em in the Army.
Always love driving trucks with skull n crossbones warnings! :shock:
blisters13
75
Beaumont in SoCal
Here's the builder's / data plate after I spruced it up:
I cleaned it with white vinegar and hydrogen peroxide (about 50% - 50%) and then sprayed it with flat black; gave it a slight curve, convex to the front, and then sanded it slowly with 600 grit emery cloth. Lastly I coated it with clear lacquer.
Soaking in vinegar:
It took 3 washes, and I think if you leave it in too long or wash too many times it will probably start pitting the surface a lot, so you have to watch it.
Viper8
Euless, Texas
Thanks for the interesting tip on restoring a data plate! I have a couple of GTBs whose data plates need lots of TLC - I'll try your process. Looks like a really nice result!!
blisters13
75
Beaumont in SoCal
Prospector- I see you're in Hesperia- I work in Pearblossom. Hope to transfer down to San Bernardino within the year. I also have an M35A2 w/w that I drive around at least once a month (but not up to the high desert!).
