- 5,580
- 345
- 83
- DESOTO, KANSAS
Dave how much for the ladder? If its in my budget I'll take itI have one like new 6 step aluminum with hand rail wide boarding ladder.
View attachment 587307 View attachment 587308
May have some others by rally time.
I have never heard from anyone on the HMMWV tow missile racks so will stay home unless I get a PM.
Same on the Litter carriers
I'll take two pairs.I want to update what I will have:
About 10 Good tested pairs of these Route Lights $100 per pair. First come first served, one pair is paid for already: I set it on the bumper of my Deuce for scale- THEY ARE BRIGHT!
Recovry, I got both buss bars I just took off a parts truck. I'll make a note to throw them in the truck and then you can take whichever one will work. I'll have to look and see, but I think I have the covers too.Folks, if anyone has parts CUCVs around I am looking for the buss bars behind the rear battery. I'd rather have the shorter ground one but I have to go home and double check that it's insulated from ground, I need it for power.
Have a SS member that will not be at the rally, he is looking for,Quote Originally Posted by 73m819 View Post
SWISS and 73m819 want and committed list
SWISS -- Need an 800 series steering column. Found one
SWISS -- Trade or Buy Looking for 11 G177 tires, can trade 7 good 14x20's, 3 are new.
73m819 -- I am looking for 4 of the cab outside grab hand holds, these are mounted on the tub just before or right at the rear corner curve of the tub,. found some
Rmtaunton -- Snatch block for 5 ton, We have MORE then 1, talk to swiss
]swiss -- Joe put swiss down for a set please (pole set)
73m819 -- Put 73m819 down for a set, thanks (pole set)
73m819 -- Looking to buy or trade for TWO clear lenses for the single light armored head lights. Will swap a pair of ir lenses for clear if someone is looking for the ir lenses.
73m819 -- Sorta looking for TWO 939 a0/a1 fuel tanks NOT a2 or tractor, or the small wrecker tank.
73m819 -- Someone buys this truck, talk to me about driving it to where it needs to go.(Sandcobras truck)
73m819 -- will take 3 81mm brown
swiss -- Another 81 brown please And 2 60
swiss -- Looking for some Jameson Florescent lights not at e-bay pricing. PM me if you have some to sell. (do not know if this has been found ???)
73m819 -- Twight, I have 3 specter fuel cans at you place (i think) that I brought from Carnac, could you PLEASE bring them to the rally, thank you. (dealt with)Thank You
73m819 -- I WILL take it (939 air drier) if joe does not. ALSO looking for a 939 foot brake treadle valve
Andyrv6av8r -- I think I have 2 driers Ron.
sandcobra164 -- Ron, I have a M939 series treadle valve with pedal, new never used. I'll confirm tomorrow, gotta dig through my parts bin.
73m819 -- I sure would like 4 PSP sections
73m819 -- Adam, I could use a metal air gauge, NOT one of those crap plastic ones.
73m819 -- looking for A 809 series front winch drive shaft.
73m819 -- looking for 200' of 5/8" NEW winch cable
73m819 -- Looking for 2 or 3 G177x20s, on or off rim
73m819 -- Looking for a METAL water temp. gauge and sending unit as a set
73m819 -- I will take a glad hand bunch, need at least two with glad hands.
73m819 -- need ONE fuel gauge selector switch with lever, a NEW need has made it self known
73m819 -- Need TWO military on/off switches with lever,
73m819 -- Need TWO 809/939 start switch with lever,
73m819 -- Need FOUR extra levers for the military switches
I think this is ALL, I hope, as it is NOW, I am going to need to acquirer a BIG trailer just to haul ALL our acquired goodies back to the AO and the FOB.
I've got BUKU fiberglas uprights (standard and extra long) w/metal corners $10/ea with quantity discounts.Part of my "house-cleaning" parts list: (for items not priced, I will accept reasonable offers)
M-816 "wiffle tree" with pins
Metal Jerry can
NEW tan Jerry cans - $60/ea
NEW 24-volt Impact wrench w/bag - $300
Bridge plate sets - $10
Slave cable adaptors (2)
Tan M105 cover
12-volt Red Candy Bar Light - $50
Slave Cable Set - $250
Deuce air tank sets (3) - $40/ea
NOS Air Tanks (9" x 37") - $25/ea
Fiberglas uprights w/corners (35) - $15/ea
Wood uprights w/corners (13) - $10/ea
Tan fiberglas uprights (10) - $5/ea
Green fiberglas uprights ( - $5/ea
Tan extra-tall uprights w/corners (20) - $200/set
Tan metal bows (10) - $15/ea
Green metal bows (6) - $15/ea
Green wooden bows (6) - $10/ea
Longbed cargo cover, camo, 900 series - $350
Pair of 900 series mirror brackets - $25
Deuce radiator, unknown condition - $200
2- Deuce radiators, flushed/tested - $400/ea
Deuce fan blade
Cummins fan blade
800 series muffler, used but solid - $50
NOS Deuce pressure plates - $30/ea
Deuce bumperettes - $30/set
Deuce driver-side tool boxes w/steps (2) - $25/ea
M101 side rail set, tan NOS - $125
M101/105 metal bow set - $125
Deuce/5-ton rear window panel - $50
M105 end rail panels, 3 tan, 4 green - $20/ea
more to follow........
Awesome. Nobody want to part with one, I'm in if you have one. Thanks!I think I have one, will take pic of the ones I have and post.
Pc, I posted in the transportation needs.Sigo, I have an almost new set down here, if you can find someone down this way to drag them up for you.
