Oil filter part number
Blackmagic94
14
Oro Valley/AZ
What over the counter part number oil filter could i source locally today?
And 15w40 for oil, how many quarts, sorry im slammed at work and dont have a lot of time to read the archives for this
doghead
4 Star General /Moderator
1,189
You can make this a useful thread and share with us the info you found, or we can simply delete this(depending on if you care to help others).
doghead
1,189
SWB, But what if you must know how much oil you need for your $100000 investments?
Work, or get right answer.... I can't decide...
doghead
1,189
This list is the third post, in the link above,
Ac pf35
champion lab ph1218
fram hp4
fram ph13
fram ph5
mobil1m1302
motorcraftfl12
purol30040
purol34631
purol35132
wix51060
wix51061
doghead
1,189
Yes, and I'm slammed right now...
Recovry4x4
LLM/Member 785
1,824
GA Mountains
Ac pf35
champion lab ph1218
fram hp4
fram ph13
fram ph5
mobil1m1302
motorcraftfl12
purol30040
purol34631
purol35132
wix51060
wix51061
Forgot the Baldwin B6 and thanks for the Sweet Brown linky.
Warthog
241
OKC, OK
Sweet Brown lives just down the road from me. She is a local celeb.
1993
Ac pf35
champion lab ph1218
fram hp4
fram ph13
fram ph5
mobil1m1302
motorcraftfl12
purol30040
purol34631
purol35132
wix51060
wix51061
are all of these compatible with the M988 6.2liter? what's the difference between Wix 51060 and Wix 51061?
could I use the wix 51794?
I've read that it is used in many of the same applications as the 51061, but it's longer so more filter surface area inside.
NH
I have both sitting on the shelf in front of me in my parts department. The difference between the Wix 51060 and 51061 is simply pressure ratings. Filters have the exact same exterior dimensions and filter elements, but the 51061 is rated for higher pressure. Both are fine on your 6.2L.
The 51794 will mount up provided there is nothing in the way. Can't remember if anything would be in the way of that big, long filter. Whether it fits or not, no real benefit in my opinion so long as you are regularly servicing your truck.
