MEP-8xx series fuel pump
Daybreak
2 Star Admiral
1,522
778
Va
MEP-802/803 fuel pump
Howdy,
The 800 series TQG has 2 different fuel pumps. The older style is a square Facet electric fuel pump. The newer style is a round Airtex E1074 fuel pump. This is the primary pump location item. A lot of the units already have these mounted, or have been replaced with the round Airtex fuel pump.
MEP-802A fuel pump (primary)
MEP-812A fuel pump (primary)
MEP-803A fuel pump (primary)
MEP-813A fuel pump (primary)
The picture below shows the components.
NSN 2910-01-565-9234 E 1074 PUMP,FUEL,ELECTRICAL 24V (pump only)
NSN 2910-01-553-6571 FILTER ELEMENT,FLUID (small barrel filter only)
NSN 2910-01-491-1340 PARTS KIT,METERING AND DISTRIBUTING FUEL PUMP (full replacement kit = pump, filter, and steel line piping*(approx. 4 inch piece)
Daybreak
2 Star Admiral
1,522
778
Va
Howdy,
I got in the NSN 2910-01-553-6571 FILTER ELEMENT,FLUID (small barrel filter only) PART# 00-24000
It is attached to the fuel pump.
odge
11
Prescott, AZ
Thanks K. Will look there. I appreciate all the info available on this sight and all the guys who take time out of there day to provide that information.
Daybreak
2 Star Admiral
1,522
778
Va
Howdy,
Civilian world = Airtex G-17 filter
DieselAddict
2,353
Efland, NC
I recently ordered 3 and its been a back and forth of backorder shipping dates. They say they are going to send them as soon as they can get them. Right now looking at the end of this month. I hope they don't end up canceling the order. I need to replace a failed one now.
DieselAddict
2,353
Efland, NC
Summit finally canceled my order. I called Airtex today and talked to one of the technical folks. He said they were bought by Carter and all the Airtex parts were being "replaced" by Carter products.
He told me the closest pump going forward will be a Carter P74016. Its slightly higher flow but the same pressure. Shouldn't be a problem. I'm going to order one and see what it takes to make it work since I have a machine with a bad pump.
https://www.summitracing.com/parts/crt-p74016
Edit: Added images before the E1074 pump disappears from the Summit website.
Also - He said that the E8135 is the same pump as the Carter P74016.
CallMeColt
1,738
Wilson County, Texas
View attachment 779708View attachment 779709
Thanks for the information. I just got notice of my canceled order as well. Going to get ahold of them & have them change the order to the part number you mentioned.
Ray70
7,226
West greenwich/RI
If you are replacing the original square pump, the E8135 is a drop in replacement, no extra fittings etc. needed just reuse the 90 and 45 degree 1/4" NPT fittings off the old pump.
I buy them from Rock Auto and ebay
If you are replacing the round E1074 with the adapter pipe you will need to buy two 1/4 NPT male x #4 JIC adapters , one 90 degree and one 45 degree. I get these from www.discounthydraulichose.com
I try to keep a couple pumps and a hand full of fittings on-hand incase a customer ever calls with a failed fuel pump, or one dies on a machine I'm working on.
If you want to install the G-17 strainer ( its not really a filter ) that is 1/8" NPT so you need to get the right adapters to install it in your desired location ( input to the pump )
Light in the Dark
6,815
MA
I was a fool to have cancelled my Summit order months ago... thanks for the info on the Carter unit Chris & Ray.
