Ive got a 87 6.2 in the hmmwv.
It was idling rough, but always started up. Today i started it and let it run and warm up. After about 5-10 minutes of running it started to stumble, then began surging. 15 seconds later or so it died, and won't restart.
Im assuming this is a fuel delivery problem of some time. Plugged filter, Bad injection pump. Maybe a bad shutdown solenoid?
My question is, what are the usual suspects/common failures?
After it died i opened the little valve on the bottom of the fuel filter housing, and diesel ran out. So i assume fuel is making it up to the filter. From there, I'm a bit clueless.
Any advice is greatly appreciated.
