Moderators~ Time for a Generator only forum!?
Tinstar
2,613
East of Edmond, Oklahoma
Administrators~ Time for a Generator only forum!?
Threads for Generators totally dominate this forum.
It makes it very difficult to sort through to find other info that isn't GenSet related.
Can the Generators have their own forum?
Looks like they certainly need it.
Just a thought.
edited to reflect administrators in title
Recovry4x4
LLM/Member 785
1,827
GA Mountains
I'm sure it will be along after the train forum. FYI, admin decides forums, not the mods.
doghead
4 Star General /Moderator
1,193
Train forum, submarine forum, crybaby forum....
Nope
Light in the Dark
6,775
MA
Not sure how this forum is set up, but I've been a moderator on a Ford Truck forum for over 15 years... and we have a forum hidden from regular users. It is for moderator and admin discussion about all topics... sometimes creations of new forums too. All the same, would be nice for someone to set it up that way.
Guyfang
27,245
Burgkunstadt, Germany
If you mean taking Power Generation out of Aux Equipment, to create a forum like The DEUCE, GAMA GOAT, CUCV, or M880, yes, it's an excellent idea.
5,175
A revision in forums will be happening. But right now I'm focusing on the move. I will however likely need assistance in moving threads.
Firebrand
19
Charlestown, NH
As a recent 803A purchaser, I would think most SS users would build more traffic given the ease of use provided by a Generators only section! Already I've spent a huge amount of time and energy scanning and searching for 803A specific threads and information. Time saved is money! Thanks in advance!!
5,175
I can spin up a sub-forum(s) under the aux section. But just like you pointed out. Finding the content and separating them is the problem. I have no magic wand to wave to move the specific content into the appropriate forums. It would be a completely manual process to sort through the aux section and place things into a category. And this typically is the point when the wheels fall off where people want it to happen, but no one wants to put the effort into making it happen. I can alternatively just setup the new sub-forums and hope/direct people to post into the new area. But that'll leave a lot of good content "orphaned" so to speak.
DieselAddict
2,354
Efland, NC
If you are looking for moderators that would be willing to help, I'll volunteer. I'm an experienced forum admin. I run the 24hours of lemons forum.
Valence
563
Davis County, UT
Have you decided to be just one Generators forum or do you want to separate the Generators by class (3KW, 5KW, 10KW, 30KW, 60KW+ etc), or by type (Gas / Diesel, or MEP-002/003, MEP-016B/701A... I'm not sure of all the differences, I only have a MEP-016B/701A)?
I would volunteer to help once it is decided how you'd like the split to be.
Light in the Dark
6,775
MA
I might be newish here, but certainly not new to how forums and thread moving works (18 years as a moderator at www.ford-trucks.com). If you are looking for volunteers, I'd be happy to help.
Tinstar
2,613
A sub-forum for Generators and related equipment.
Then within that you can search for gas, diesel, Kw size etc.
or however it's decided.
It would be a lot easier than it is now looking and searching for info that isn't genset related
Guyfang
27,245
This is the only way I could get my posting to work.
Have you decided to be just one Generators forum or do you want to separate the Generators by class (3KW, 5KW, 10KW, 30KW, 60KW+ etc), or by type (Gas / Diesel, or MEP-002/003, MEP-016B/701A... I'm not sure of all the differences, I only have a MEP-016B/701A)?.
At last count, I have about 30 different gen sets, not counting 24 volt output models, 400 hertz models and the digital models. And I only looked at 0.5 KW up to 60 KW. Thats a lot of work. Like I said, I am willing to help. If a few people all help whenever they can, it should be do-able to move threads. May not happen all at once, or even fast. But do-able.
Some of the sets I counted, rarely come up, and some have never come up. But we could come up with a short list and don't worry about the model differences. Everything else could fall once again under "AUX" equipment, a sub heading in the Power Generation forum.
