- 200
- 16
- 18
- Columbus, Ohio
Hello,
I searched and found a few threads but nothing with all the details.
I am looking to increase the HP of my Cat 3116 powered LMTV.
The engine is currently rated at 225HP and I want to upgrade to the 290HP level of the FMTV.
I did some comparison of the parts manuals etc between the two engines and have found the difference in parts are the turbo and governor.
The turbo for the 290 HP version is part number 4R-8915, I was able to find a NOS one for a good price.
The Governor is basically the same between the two HP ratings with the exception of the Torque cam and Control AS ratio.
The way I understand it the Control AS ratio retards the fuel rack under low boost pressure and the torque cam adjusts the fuel rack movement under load, as I am not a diesel mechanic I may be wrong.
The fuel setting for the 290hp is a bit higher and the injector timing dimension only slightly different, the details can be found on the engine spec plate.
I plan to install the bigger turbo soon and make the corresponding fuel and timing adjustments per the spec plate for a 3116 with 290HP.
I am still considering whether the governor parts need changed and or any governor adjustment is needed.
Some sources advise to adjust the governor air ratio screw out a turn.
If anyone here has advise regarding the governor needing changed/ adjusted I would appreciate it.
I plan to install a boost gauge and pyro before the turbo swap.
