justacitizen
- 40
- 28
- oklahoma
after all of this guessing and chasing it would probably benefit you to run a compression check on all cylinders. then you will know for sure and can cross that off of your list before advancing on into the fuel system. confirm compression and air then fuel. i assume that while you had the front cover off you checked the cam timing???
