russojap
- 0
- 16
- Knoxville TN
Too many amps...Why did they melt in the middle?
Could I put that conducting grease inside the bolt holes to prevent this from happening again?Too many amps...
The bolt and the lug on the end of the cable is so crusty, it’s making better contact on the bolt which is arcing on the interior of the hole through the lead, melting from the inside out.
Thanks, I like the look of these, should be quite a bit harder than lead so you can crank them down good, and the cable end part has lock washers.It wouldn’t hurt, but that lug needs to be sanded bright on both sides, new bolt, stainless nuts, and bolts are really nice, as well as brass terminals.
