- 122
- 81
- 28
- Port Angeles, WA
So which coil overs did you go with?
I went with 1000# springs up front, but with a GMV bumper and a Sherpa winch, it's sitting about 1.5" too low. Rides great, would like it a bit higher though. I know I can do the 1200# winch springs, but was curious about your set up.
I used a router personally but you could use a table saw, reciprocating saw or even just leave it. The router allows you to ease the inside corner of the spacer to fit over the lip of the mount. The spacer has a flat bottom and mount has a lip.
I have since upgraded to coilovers in the front. I like the adjustability of spring swaps, and shock valvings. If someone was to do this I would suggest do the rears first. Then decide what they want with the fronts.
daystar KN09103BK
