KnuckleDuster
- 42
- 13
- New jersey
I recently purchased a 2009 mep802a from govplanet with a trailer for $900. Sold the trailer as I don't need it for $600 and got started on the generator. I found the alternator was missing, fuel bowl, battery cable, and the 3 amp fuse for the voltage regulator were all missing as well. Sourced all new parts got it all put back together bled the fuel system and got it cranking. No start. Not even an attempt. Shot a sniff of starting fluid into the intake and it didn't even sputter. I know it's not a fuel concern. Pulled the dipstick while cranking and the pressure coming out of the crankcase was pushing oil all the way up the dip stick tube. Starting to think maybe a stuck or broken ring. Anyone come across this? Unit is high hours, sitting right at 3400. Found the shipping tag and it was actually in Kuwait working. Thanks for any advice! Not sure if im missing something else to check
