abfisher1798
- 86
- 28
- Blythe, California
Starts just fine. On the open road with the pedal to the floor, the tach pegs at 1500 RPM, about 15 MPH (speedometer not working), barely moves down the road. It struggled to get over the small hump that railroad track straddles.
I thought that it's stuck in low gear. The transfer case shifts to neutral just fine. Seems to shift into high gear with the results described earlier. I also shifted it to low gear and there was no change in performance.
Transmission is brand new and shifts through all the gears. After 30 or so mins it began sputtering/surging but maintained speed. Check engine light is not on, and a diagnostics reader shows no error codes.
If anyone has any insight or guidance, I'd very much appreciate it.
Thanks.
Thanks.
