- 680
- 943
- 93
- Southern Minnesota
The pin from the 90 degree adapter broke off in my speedometer gear. To diagnose everything I removed the Speedometer Adapter (TM 9-2320-280-24P-2 Figure 488 Part 19) and the gear (part 17). Verified the pin was broken off inside of the gear (17) and no way for me to get it out. So I'll have to order a new gear.
Transfer case is an NP218 - 261 gears according to the tag.
Reading the re-installation instructions from (TM 9-2320-280-20-2 Page 5-50) it says:
- Numbers on pinion adapter represent number stamped on driven gear. When installing adapter, numbers on adapter must match with numbers on transfer case housing.
I figured this would be obvious, but the more I look the less I believe I have any idea what I'm doing. So I'm looking for a clue.
There is a bit of a diagram, but for the life of me with the exhaust right there, I simply can't find the numbers of an indicator for alignment.
I did put it back into the hole and I rotated it clock-wise until it stopped turning then put the lock on it. Is this the right way to do it, or does someone have better guidance for me?
Everything else was straight forward, but I really don't know if what I did is going to cause internal damage or not. (I just need this to block the hole until I get the new gear I ordered, but when the new gear arrives that needs to get installed properly as well...)
Any help/suggestions/guidance would be appreciated! Thanks!
