Mfoley
- 7
- 3
- Raliegh, NC
Purchased this one knowing it was not running and had been pretty well cannibalized. I have gotten it back together and it is now running and moving well just 2nd gear. I realized I am not getting ignition power to the trans or the TCM. I replaced the transmission relay and now have power at 291C with the ignition on. I also have power at the brake switch and trans lamp. However the trans lamp is not coming on. No power on transmission J1 -E (290D) or TCM- J (291-D). I do have 12v battery on 537-D at TCM .
I have traced the wiring harness and cannot find any points that look damaged/ ripped or disconnected. The wiring diagram shows power for these 4 connections are coming from lead 3 at the trans relay and split off somewhere in the wiring harness… I’m assuming. Or do they connected somewher? What am I missing? I downloaded the transmission troubleshooting guide and tried jumping the test port on the TCM to get the trans light to come on But without ignition power does this test work?
I definitely would appreciate any help. Thanks Matt
