- 166
- 119
- 43
- California
I don't believe the hand pump or air/hydraulic pump are working now,Hand pump is not working
Meanwhile, the immediate problem is solved. The problem was not the hydraulics at all, but rather a mechanical interference. The cab was landing on and stuck on the arch that holds the cab lock. Judicious application of a crow bar solved the problem
Thanks guys for putting up with me, I appreciate it.
I've ordered the hand pump setup that Ronmar is using and when it arrives, I'll install it. Meanwhile, I won't be raising the cab until the new hand pump is installed and the cab lock re-built.
