Third From Texas
- 6,676
- Corpus Christi Texas
Yeah, the pandemic really crippled the custom shock world. The survivors are still recovering.
I'd start with a 3" body and talk to them about how best to do the can (likely going to be a remote), Maybe get your actual curb weight (CAT scales) for the front axel (that would be how I'd "fuzzy" it). Give them those weights and see what they recommend for valving/bypass. You're not really going to be racing it, so you have a lot more fudge factor to play with. And depending on how they valve them, you might be able to get away w/o a bypass.
But that's likely how I'd start the discussion with them. One of their techs should be able to sort it out. But I haven't dealt with King (or any of the others) in a lot of years. Sounds like you have the time, so that works in your favor. But it's quite the expense, obviously so you want it right for sure.
