wreckers?
res0wc18
Everett, Wa
hey guys what are all of the designations for the wreckers? do they all have front winches?
Anyways a friend of mine and i are trying to put together all of the wreckers designations.
maddawg308
821
Appomattox, VA
I believe all wreckers have front winches. I may be wrong, but I can't remember seeing one without a winch.
In order of size:
XM711, Truck, wrecker, light, 3/4-ton, 4x4 (M37 chassis), very rare
M60 Truck, wrecker, light, 2 1/2-ton, 6X6, (M35 chassis), very rare
M108 Truck, wrecker-crane, light, 2 1/2-ton, 6X6 (M35 chassis), very rare
M62 Truck, wrecker, medium, 5-ton, 6X6 (M39 chassis), common
M246 Truck, tractor-wrecker, medium, 5-ton, 6x6 (M39 chassis), uncommon
M543 Truck, wrecker, medium, 5-ton, 6X6 (M39 chassis), common
M816 Truck, wrecker, medium, 5-ton, 6x6 (M809 chassis), common
M819 Truck, tractor-wrecker, 5-ton, 6x6 (M809 chassis), uncommon
M933 Truck, tractor-wrecker, 5-ton, 6x6 (M939 chassis), never built/concept
M936 Truck, wrecker, medium, 5-ton, 6x6 (M939 chassis), common
M533 Truck, wrecker, 8-ton, 4x4 (M520 GOER chassis), rare
M553E1 Truck, wrecker, 10-ton, 6X6
M984 Truck, wrecker, heavy, 10-ton, 8x8 (HEMTT chassis), common
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
Even though you'll find it in some older TM's, the 900 series tractor wrecker (M933) is a mythical beast that wasn't actually produced.
maddawg308
821
Appomattox, VA
I updated the list with commonality of the vehicles, related to how often they are seen. The last one I'm not sure, I pulled the designation off the "M" list, but I have no idea what it is. I also am missing the designation for the HEMTT wrecker.
gimpy - I know, some call them wrecker-cranes, but once again, I pulled the above info from the "M" list, and I used keyword search to find anything with "wrecker" in it.
BKubu
1,241
Gaithersburg, MD
The HEMMT wrecker is the M984. There might be an M984A1 and M984A2 or something...but the M984 is the base wrecker.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
And there's the M246 tractor wrecker. The M108, that Gimpy says isn't really a wrecker, was available wo/w (or at least has an NSN for that). Now as far as the cool factor Gimp was referring to, that has yet to be determined. He's a commoner and Stretch and I are rare, and we shouldn't forget members M108 and Rizzo who are owners of this little prize.
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
I was already a cool guy, M108 just makes me a really cool guy!
And the data plate says crane on the M108, but I'm sure it will get some wrecker duties at some point.
Dennis
73m819
329
gainesville, ga.
as a side note, the 108 was built as a bomb handling truck, but found use as a light wrecker, so a military mind with a higher pay grade then myself came up with the m60 with the thought that it would make a GREAT light to medium wrecker, only after production which was a gasser did the great mind realize that the 2 1/2t m60 was to light to do recovery work except very light vehicles, it had a VERY HARD time even with other deuces, so the end of the m60
