I'm a "functions" kind of guy and like to compare the things that actually do or don't make a difference, not just features that impress somebody looking at the truck.
Covering the right side of the vehicle with a huge blind spot (air intake/exhaust) is not good. At a show once, I stood in that area and took some pictures without the driver even noticing me.
External air filter is good, keeps the air cooler, but like the 5-ton placement better (on top of the fender).
The axles are the same. Shocks are bigger. Same axle breather valves.
The CTIS has limited usefulness.
How long does it take to cycle from 60 psi to 10 and then back to 60? Twenty minutes? Can't really be used in sub zero weather. Needs air dryer, which must be heated around the clock in cold weather unless an alcohol evaporator is added.
The wheels and tires add 1,000 lb of unsprung weight to the vehicle.
Like the straight shackles on the bumper and the single centered one, but don't know if that's stock.
No multifuel. The Cat engine (3126?) could probably be critized also, but don't know enough about it (Glow plugs, how long can it operate at full power, cold weather starting problems, etc).
Tires are not much better than NDCC's on wet pavement. Read somewhere that bias ply tires are better in sand. Bias ply tires have tougher sidewalls for off-road duty, 12-ply on the 1100's.
Top speed about the same as the A2.
Don't like automatic transmission.
Don't like headlights on the fenders (or in the bumpers like the FMTV's). Easily damaged.
West coast mirrors are no good off road.
Don't care for comfort items in a tactical vehicle. Sound proofing etc.
Anybody know how long the ESP program lasted?
I like to say that "some things can't be improved on just made differently".
This should get a discussion going.
![Twisted Evil :twisted: :twisted:](https://www.steelsoldiers.com/images/smilies/icon_twisted.gif)
